It is currently Fri Aug 22, 2025 10:59 pm
PostPosted: Sat May 21, 2011 5:39 pm
How do you like to see it? Having this discussion with a buddy today...the situation is that the neck block/paddle arrangement is already in place...the UTB should have the paddle butting right into it to counter any rotational action of the fingerboard extension/upper bout under string tension...thing is, with the length of the paddle, butting the UTB against it means the brace runs into the "inside" edge of the cutaway...not all the way across into the "point"...the point does have a fair amount of "meat" at the tip tho...any ideas, wisdom, etc.?
PostPosted: Sun May 22, 2011 12:39 am
I set mine UTB at an angle on cut-aways as can be seen in this photo.
PostPosted: Sun May 22, 2011 8:27 am
First name: Woodrow
Last Name: Brackett
City: Grover
Zip/Postal Code: 28073
I'd angle the UTB like Jim does. There's been some recent discussions about leaving the end of the neck block tougue short of the UTB anyway. You could probably take some kind of hand saw and cut it at an angle to fit after it's in anyway.
PostPosted: Sun May 22, 2011 12:10 pm
First name: Daniel
Last Name: Minard
City: Powell River
State: BC
+1 on angling the UTB. I angle the upper back brace too.
Users browsing this forum: Bing [Bot], doncaparker and 9 guests
