It is currently Sun Sep 14, 2025 7:48 pm
PostPosted: Thu Apr 17, 2014 8:21 pm
First name: Ben
Last Name: M
City: Bristol
State: RI
Hello all,
I just wanted to introduce myself. I've been lurking around here for a number of years and finally joined. I'm sure I have met some of you at the 2009 and/ or 2013 A.S.I.A. symposiums.
Below are a few pictures of my #2 which I finished recently. It has a long tenon neck, which extends just past the bridge. It's a tribute to three of my favorite Texas guitarists - Billy Gibbons, Jimmie Vaughan and SRV. A friend from work who has an original '58 burst played it last week and thinks it plays and sounds amazing, so I definitely feel good about that! Unfortunately, I lost my shop access when my cousin (a cabinet maker) passed away, so I was not able to spray the finish myself, as I did for #1. That being said, many thanks to Brian Howard for the fine finish job!
PostPosted: Thu Apr 17, 2014 8:25 pm
Digging it!
PostPosted: Thu Apr 17, 2014 8:27 pm
First name: Ben
Last Name: M
City: Bristol
State: RI
Oops, forgot the question. I had to move the bridge saddle close to all of the way back for proper intonation. The bridge placement is right on with the spec listed on Stew Mac's website. I guess my question is, if I use a different bridge on #3 (the same design as #2), should I trust the measurements they list? I think that i was 1/8" short of what would have been ideal for bridge placement with this hardtail bridge. Any advice? Thank you in advance for your help.
PostPosted: Thu Apr 17, 2014 9:57 pm
I have found the measurements on the Stew-Mac calculator to be accurate about 50% of the time. You'll have much better luck setting the saddles to the middle of their range and placing the bridge so your string length is the scale length plus 1/8".
Good looking guitar, Brian did a nice burst for you. I see Billy, where are the Vaughn brothers hiding?
PostPosted: Thu Apr 17, 2014 10:14 pm
First name: Ben
Last Name: M
City: Bristol
State: RI
Thanks! I'll have to check out that measurement against this bridge.
Well, if you look a little closer, the Reverend is playing SRV's Number 1 and the truss rod cover has a spade inlay with Jimmie's initials (in the style of his initials on the Out There album art, if I remember correctly)
-Ben
PostPosted: Fri Apr 18, 2014 7:05 am
Last Name: Howard
City: Magnolia
State: Delaware
Zip/Postal Code: 19962
So, How does it sound?
Brian
PostPosted: Sat Apr 19, 2014 9:33 pm
First name: Ben
Last Name: M
City: Bristol
State: RI
It sounds unbelievable! The sustain is great, so I'd like to think that can be attributed to the design with the long-tenon neck. Sounds really good unplugged, and the Pearly Gates P/Us really complement everything well. The PG's would probably sound good screwed to a 2x4 though!
PostPosted: Sun Jun 01, 2014 12:52 pm
Thats really an amazing looking instrument.... especially for a #2.... no pun intended...
cheers
charliewired
PostPosted: Sun Jun 01, 2014 3:26 pm
First name: D
Last Name: S
I like everything about it. The inlay and finish are killer.
Yep, Steven is right on for locating the bridge. Measuring from the nut to a mounting hole is silly.
I might add, if using a Gibson 24-3/4 scale, measure from nut to 12th fret and multiply by 2 to get the actual scale length. Gibson used several different scales referred to as 24-3/4.
wah
Wah-wah-wah-wah
Wah
PostPosted: Fri Jun 06, 2014 12:15 pm
First name: D
Last Name: S
It would be great to see some more pictures.
Don't be shy, an awesome guitar like yours needs to be showed off!
wah
Wah-wah-wah-wah
Wah
PostPosted: Sun Jun 08, 2014 8:26 pm
First name: Ben
Last Name: M
City: Bristol
State: RI
Thanks everyone! Here are a few pictures of the back and neck to body joint:
PostPosted: Sun Jun 08, 2014 8:46 pm
First name: D
Last Name: S
Nice!
wah
Wah-wah-wah-wah
Wah
PostPosted: Mon Aug 25, 2014 2:32 pm
First name: Jim
Last Name: Outman
City: LaGrange
State: GA
Zip/Postal Code: 30240
Cool. Very good attention to details.
PostPosted: Mon Aug 25, 2014 9:50 pm
First name: Jeff
Last Name: Dillard
Wow nice burst, and those boys from Texas ,man can they play!
cron
