It is currently Mon Aug 04, 2025 9:27 am
PostPosted: Thu Feb 16, 2006 2:42 am
A beginner question...since I have only set up a handful of instruments.
What is the best way to clean out the finish that gets in the tuner holes
during finishing. I already once ruined part of the finish on a prevous
instrument. Do you try to get sandpaper in there?? Do you redrilll???
I find it very hard with Waverly solid peghead tuners, since the holes are 2
different sizes.
Andy
PostPosted: Thu Feb 16, 2006 2:43 am
I use a hand held reamer.
PostPosted: Thu Feb 16, 2006 3:08 am
same here and a dowel with some 320p for light touch up
PostPosted: Thu Feb 16, 2006 3:10 am
The problem with the reamer is that it is tapered and won't clean all the way
down the hole...esp the bushing side of a waverly tuner hole....since it is 2
sizes.
What do you do....or what kind of reamer do you have
Andy
PostPosted: Thu Feb 16, 2006 3:22 am
That is what the dowel is for. You can buy straight reamer. they are tapered on the leading end but go to straight after a 1/2" or so . Check local machine shop supply houses in your area
PostPosted: Thu Feb 16, 2006 3:23 am
Same.
PostPosted: Thu Feb 16, 2006 4:22 am
Try the drill bit you used to drill the hole but make sure it is running in reverse or it will tear out. This works pretty well.
PostPosted: Thu Feb 16, 2006 4:44 am
I use the same size drill bit I drilled the holes with, put a handle on it( dowel with a hole drilled in the middle) and use it for a hand reamer.
PostPosted: Thu Feb 16, 2006 9:42 am
Why the need to ream? I drill the hole 1/64" or 1/32" larger in size than the diameter required, fill the hole with paper towel during finishing....no major reaming required other than touch up at the edges.
PostPosted: Thu Feb 16, 2006 9:49 am
foam ear plugs, then cut off the access with a razor blade
PostPosted: Thu Feb 16, 2006 10:04 am
[QUOTE=MichaelP] foam ear plugs, then cut off the access with a razor blade [/QUOTE]
what a cool idea! Thanks for sharing Michael!
PostPosted: Thu Feb 16, 2006 11:12 am
That's even a better idea!
PostPosted: Thu Feb 16, 2006 11:35 am
I dont know why that popped into my head, because I have never use it before ... but for some reason and only my hair dresser knows for sure why, the light bulb went on up stairs
PostPosted: Thu Feb 16, 2006 3:47 pm
What an awesome idea with the ear plugs. At the MRI center where I work,
they have tons of them. I will just save the next set or 3 that I use.
Andy
PostPosted: Fri Feb 17, 2006 5:39 pm
Michael yer gonna end up on the TV show NAMED " HOW'D THEY DO THAT!
TOU ARE AWESOME!
