It is currently Sun Nov 24, 2024 4:32 am
 Post subject: LMI yellow
PostPosted: Wed Jun 28, 2017 9:04 am
Last Name: Wood
City: Chester Springs
State: PA
Zip/Postal Code: 19425
Hey all,
I'm curious what you all think of the new LMI yellow glue? I've always used the old white LMI product and really liked it. So far, I can't say I'm crazy about this new stuff. Seems like the old glue had a longer open time, and so cleanup was easier. Plus, I thought the old glue dried nearly clear and this stuff is YELLOW!
What's everybody using now?
Chris-
 Post subject: Re: LMI yellow
PostPosted: Wed Jun 28, 2017 11:27 am
City: Vancouver
Titebond OG, hide glue for bridges, sometimes for bracing on our top brand.
These users thanked the author meddlingfool for the post: Lucku_Luke (Wed Jun 28, 2017 4:02 pm)
PostPosted: Wed Jun 28, 2017 12:47 pm
Most likely some type of PVA, I used their glue for a while and it worked great.
Currently however I'm using only Hide Glue for the guitar assembly (Fresh Mix, and Old Brown Glue which has a long set time). Hide glue doesn't creep, it soaks into the fibers better and the strength is fantastic (plus cleanup is easy). The only exception is that I use CA for rosettes and bindings, I get mine from the Hobby Store in Thin and Thick, the thin wicks into the joint making a strong bond, and the thick will fill in gaps. Plus is does not stain the wood in my experience.
I've been determined to use and many old techniques as I can in my building, I have a CNC for instance, but I only use it for jigs, everything else I try to do by hand...
-Paul-
-Paul-
Patriot Guitars
These users thanked the author Sprockett for the post: Lucku_Luke (Wed Jun 28, 2017 4:03 pm)
PostPosted: Wed Jun 28, 2017 1:14 pm
First name: Jay
Last Name: De Rocher
City: Bothell
State: Washington
My experience with the new yellow glue compared to the old white glue has been the same as yours. Shorter open time, squeeze out doesn't clean up as easily, and the thing I dislike most is just what you mentioned about it not drying clear like the old glue. I plan to switch glues after the current bottle is done.
These users thanked the author J De Rocher for the post: ChuckH (Wed Jul 05, 2017 8:50 pm)
PostPosted: Wed Jun 28, 2017 2:28 pm
Last Name: Miller
City: Wood Dale
State: Illinois
I have been using the LMI glue but I'm switching to carpenters glue from Lee Valley on the advice of a luthier friend much more accomplished than myself. Dries to a tan color and has gap filling qualities. The squeeze out of LMI glue is very hard to get rid of if allowed to dry. The LV glue is not.
PostPosted: Wed Jun 28, 2017 2:41 pm
Similar experience here too. Not drying clear doesn't bother me so much but the squeeze out dries real fast and gets gummy making it hard to clean up. I do like the short clamp time though. I'll probably just go back to good old Titebond next time round.
PostPosted: Wed Jun 28, 2017 3:01 pm
First name: Jay
City: Bothell
State: Washington
Yes, gummy is the word for the squeeze out. It's weird because I had the "opportunity" to take apart a joint glued with yellow glue and the glue in the joint was just as hard as expected. Squeeze out with the old glue dried solid, not gummy, and came off easily.
These users thanked the author J De Rocher for the post: klooker (Sun Jul 02, 2017 10:23 pm)
PostPosted: Wed Jun 28, 2017 4:36 pm
Last Name: Wood
State: PA
Thanks for the replies. Gummy is just the right word. I really don't like anything about the new stuff. Looks like it'll be Titebond for me. What's your favorite Titebond? I've heard good things about Titebond II.
Chris-
PostPosted: Wed Jun 28, 2017 5:28 pm
If you liked the original LMI White glue, try Titebond Translucent Glue. It will make you wonder if that was what LMI was bottling. It dries clear and is easy to work with.
I buy twin packs from Amazon.
https://www.amazon.com/s/ref=nb_sb_noss ... %2C+2+Pack
Mike Franks
www.mjfranksguitars.com
These users thanked the author Mike Franks for the post (total 4): ChuckH (Wed Jul 05, 2017 8:52 pm) • cwood8656 (Sun Jul 02, 2017 9:28 pm) • jfmckenna (Thu Jun 29, 2017 8:21 am) • J De Rocher (Wed Jun 28, 2017 9:55 pm)
PostPosted: Thu Jun 29, 2017 8:51 am
+1 for Lee Valley. I've been using their glue for any dark woods for many years. Drys very hard and has great strength.
Using HG more and more though.
PostPosted: Thu Jun 29, 2017 2:17 pm
Last Name: Collins
City: Argyle
State: New York
Zip/Postal Code: 12809
Elmers Carpenter glue /some time mixed with Fish glue for more open time
Mike Collins
PostPosted: Thu Jun 29, 2017 8:51 pm
Last Name: Wood
State: PA
Thanks everyone, for the help.
Chris-
PostPosted: Sun Jul 02, 2017 9:27 pm
Last Name: Wood
State: PA
Threw out the LMI yellow glue today. It was no picnic cleaning out the GluBot, but I did get it done. Replaced the yellow glue with Titebond Translucent Wood Glue, which, so far, I like just fine. Thanks again for the help, everybody.
Chris-
PostPosted: Sun Jul 02, 2017 9:50 pm
I've been using Tightbond Extend after reading a discussion on the now defunct Professional Luthiers Forum. I think Howard Klepper recommended it. It seems to dry hard like the old LMI white. I like it.
These users thanked the author Terence Kennedy for the post: Pmaj7 (Thu Jul 06, 2017 12:26 pm)
PostPosted: Mon Jul 03, 2017 9:47 am
First name: Kevin
Last Name: Looker
City: Worthington
State: OH
Zip/Postal Code: 43085
Here's an old thread that should be helpful.
Hugh Evans who used to work at Titebond commented.
viewtopic.php?f=10101&t=31065&hilit=titebond
I'm not a luthier.
These users thanked the author klooker for the post (total 2): J De Rocher (Mon Jul 03, 2017 12:40 pm) • jfmckenna (Mon Jul 03, 2017 11:23 am)
PostPosted: Thu Jul 06, 2017 11:14 am
I just received a reply from Franklin to my question of which of the Titebonds is best for creep resistance and hardness:
"Titebond Extend is our best product for creep resistance."
PostPosted: Thu Jul 06, 2017 2:09 pm
First name: Willard
Last Name: Guthrie
City: Cumberland
State: Maryland 21502
Zip/Postal Code: 21502
Country: United State
We are using 192g and 315g hot hide, plus a limited amount of fish for binding. We use some Titebond for jigs and fixtures where strength or creep behavior is not an issue, and Extend or Original gets the nod there.
FWIW: Because the boss starts us out on hot hide glue before he allows us to use other adhesives, by the time we pick up from other builders or forum posts that hide is supposed to be hard to use, we are already quite comfortable with it for most operations.
For the times they are a changin'
- Bob Dylan
PostPosted: Thu Jul 06, 2017 9:39 pm
I guess it's all a matter of what you are used to. I'm used to going down to the local hardware store and buying a bottle of Titebond and then building guitars with it :D
Being there just the other day though, I didn't see any Titebond Extend or any of their other products except for Titebond II and III.
I guess I thought that extend was just a dilute version of original but that can't be the case if it's more creep resistant.
PostPosted: Sat Jul 22, 2017 3:46 pm
Last Name: O'Melia
City: Huntsville
State: Alabama
I remember that thread. I use Original only. Except when I am building purfling stuff that has to go through the bender.... Tite Bond III for that. Works great.
PostPosted: Sun Jul 23, 2017 6:05 am
We like Titebond Extend too for better creep resistance and longer open time when working blind inside a box doing something that can barely be reached.
My only complaint about the stuff is having to wear a hat and sun glass when taking a bottle of it to the register.....
These users thanked the author Hesh for the post: CraigG (Sun Jul 23, 2017 11:15 am)
PostPosted: Sun Jul 23, 2017 8:05 am
Last Name: Farmer
City: Durango
State: CO
I'm used to explaining to folks that the glue used to build their instrument turns to chewing gum when it gets warm and fixing thier guitar is going to be very expensive. :D
I was told by Franklin years ago Extend is Original with "wood Cellulose" in it. That's the stuff that settles on the bottom of the bottle that should be mixed in before use. The Cellulose slows the release of moisture to give more open time. I don't understand why that would give it such a higher heat resistance though.
At least they don't keep it behind the counter and force you ask for it by name. :oops: :)
These users thanked the author david farmer for the post: Hesh (Sun Jul 23, 2017 8:48 am)
PostPosted: Mon Mar 29, 2021 1:03 pm
First name: Terry
We use HHG 315g for everything that doesn't require the open time. Just about everything else is Tightbond II or III (depending on the color of the wood), and finally Epoxy for carbon fiber rods, fretboards and inlay. Of these, the biggest challenge is doing bindings and perflings at the same time with the TB II. It tacks up before I'd like, but I manage.
PostPosted: Mon Mar 29, 2021 1:39 pm
Last Name: Parchem
City: Seattle
State: Wa
Zip/Postal Code: 98177
Never use LMI Instrument glue for a saw dust fill for a binding gap. It is made to fluoresce. Handy to find finger prints. I was watching one of my guitars being played on a stage where they were using some black lights ... Oh dear!
PostPosted: Mon Mar 29, 2021 2:54 pm
That's interesting. I almost always hear luthiers say to stay away from TB2 or 3. What do you use it for and what is your reasons?
Another tread dug up by a spammer but oh well....
I have started using 192g hide glue with added salt for just about everything now. The formula I use requires heating up but it makes the open work time significantly longer. I make up a small batch, about 3oz probably, and put in a glue bottle with stainless steel nuts in it so that it sinks to the bottom of the water bath. Works like a charm.
PostPosted: Mon Mar 29, 2021 4:18 pm
State: West Somerset
Country: UK
Hey John now that is funny! If CA did that I would be seriously embarressed Dave
Users browsing this forum: DennisK and 29 guests
