It is currently Thu Aug 07, 2025 4:56 am
Post new topic Reply to topic  [ 32 posts ]  Go to page Previous  1, 2
PostPosted: Wed Apr 12, 2006 10:29 am
I'd do a 13 fretter just cause it is cool. But if I was dead set on a 14 fretter, I'd probably make a bigger rosette. But I would have to measure everything out to make sure it would cover it. Good luck!
PostPosted: Wed Apr 12, 2006 10:53 am
Last Name: Beaver
City: Lake Forest
After reading all the info here I think I would go with a 12 fret/20 fretter. That's how Martin does it's 000. It would make a sweet guitar. With a 24.9 scale the guitar will measure about 5.4" from the 12th fret to the 21 fret (end of fingerboard) and about 7.3" from the 12th to the center of the sound hole. Yep! That should do it!
Joe Beaver
Maker of Sawdust
PostPosted: Wed Apr 12, 2006 5:29 pm
First name: Coe
Last Name: Franklin
City: Decatur
Another suggestion I got today is to go 12 frets with a sloped shoulder.
As far as playability, is it harder to get used to a 13 vs 12 fret?
I must admit that I`m not a bona fide guitar player yet but I`m the only piano player in town, so please don`t shoot me.
PostPosted: Wed Apr 12, 2006 10:03 pm
What's a piano? does it have strings too?
PostPosted: Thu Apr 13, 2006 5:15 am
Last Name: Beaver
City: Lake Forest
Serge,
Sure, it has strings. The only difference is you have to lay on the ground to tune them... I suppose that's not so bad if you are tired....
Joe Beaver
Maker of Sawdust
PostPosted: Thu Apr 13, 2006 11:08 pm
I would like to add an inexperienced thought. If, in whatever you choose, you have to cut out the sound hole through the knot, or rout through it for the rosette, I would sure soak it well in CA to try and keep it from chipping apart.
PostPosted: Fri Apr 14, 2006 1:01 am
Joe, the only piano i knew was named Bill! And no need to tune the guy's strings so far! Just kiddin'!
