It is currently Sat Jul 19, 2025 6:05 pm
PostPosted: Sat Jun 17, 2023 10:52 pm
City: Escondido
Zip/Postal Code: 92029
I never do solid colors, but my niece has asked for a gloss black electric guitar. Can anyone recommend a rattle can for applying a solid black base coat. I will likely add a Mohawk clear lacquer top coat (although I’m always open to suggestions for getting a good solid black high gloss finish).
Why rattle can? I’m just assuming it is the cheapest way to get a one-guitar solution. Educate me, please, if I’m wrong. Perhaps lacquer is wrong, and I should go with some automotive finish? One of those spray cans where you slam the bottom to release a catalyst?
In any case, twenty years of trying to apply the thinnest finish possible and make the wood’s beauty shine through hasn’t prepared me for this request.
PostPosted: Sat Jun 17, 2023 11:43 pm
First name: Josh
If you are experienced with gloss nitro stick with nitro. Stewmac has black nitro rattlecans and Mohawk do too. If you’ve got a spray gun, just add a little black pigment to whatever lacquer you normally spray. Lampblack is pretty cheap.
These users thanked the author joshnothing for the post (total 2): Hesh (Sun Jun 18, 2023 2:53 am) • Pmaj7 (Sun Jun 18, 2023 2:46 am)
PostPosted: Sat Jun 17, 2023 11:56 pm
I buy Tamiya acrylic lacquer in the rattle can at Hobbytown, USA.
These users thanked the author Chris Pile for the post: Pmaj7 (Sun Jun 18, 2023 2:46 am)
PostPosted: Sun Jun 18, 2023 2:55 am
Second the StewMac black rattle can, nice stuff. I've found the last 1/3 of the cans spit though at least mine did. Disrespectful things can't take them anywhere but I digress. So maybe buy enough with the idea that you will want to toss the last 1/3 of each can instead of be upset with what happens next.... ;) I would stop at the last 1/3 and then use that for jigs and stuff that did not matter, much.
PostPosted: Sun Jun 18, 2023 4:49 pm
First name: D
Last Name: S
Stewmac rattle can worked well for me.
If you spray through a gun, Mixol pigment can be added. Local Woodcraft sells Mixol.
I used black dye on bare wood, sprayed black Mixol in lacquer, then clear coat.
Don’t fret when polishing. It’s impossible to remove swirl marks.
wah
Wah-wah-wah-wah
Wah
PostPosted: Sun Jun 18, 2023 6:13 pm
City: Escondido
Will Mixol make it opaque? I have Trans Tints, but I didn’t think I would get an opaque base coat with dyes.
PostPosted: Sun Jun 18, 2023 6:22 pm
First name: Josh
Mixol will get you an opaque result if you use enough of it.
PostPosted: Mon Jun 19, 2023 7:43 am
Mixol is not really a dye like Transtint, but more of a stain or colorant.
PostPosted: Mon Jun 19, 2023 10:47 am
It's not a guitar - but it's painted with Tamiya gloss black lacquer from a rattle can...
https://i.imgur.com/xEilJ4p.jpg
PostPosted: Mon Jun 19, 2023 12:10 pm
City: Escondido
That is very nice. Is there clear gloss on top, or the straight black?
PostPosted: Mon Jun 19, 2023 1:09 pm
Straight black.
PostPosted: Mon Jun 19, 2023 5:23 pm
First name: David
City: Napa
Zip/Postal Code: 94558
Stewmac and Allparts has Black in a rattle can.
