It is currently Sun Jul 20, 2025 11:54 am
 Post subject: Heel cap difference ....
PostPosted: Thu Oct 12, 2023 5:37 pm
First name: David
Last Name: Harris
Ok , this will probably start something but I have noticed a difference in tone with a difference of heel cap material . I recently fitted a heel cap to an acoustic as a final operation . Having played the guitar a fair bit before hand , I was familiar with the tone . After fitting a rosewood heel cap to a mahogany heel the tone has markedly changed for the better . Even rubbing a finger on the cap can be heard throughout the entire guitar . I have since read the information on this and there seems to be some division .
I can attest 100% to noticing a large difference in brightness and clarity , this is real . I am just a bit surprised at there being any difference at all . Ok there you have it . So , choose wisely , Peace .
PostPosted: Thu Oct 12, 2023 5:45 pm
First name: David
City: Napa
Zip/Postal Code: 94558
Ok I'll bite, this has nothing to do with the Tone. You probably had a gap behind the heel prior to adding heel cap lol
PostPosted: Thu Oct 12, 2023 6:19 pm
First name: Brad
Last Name: Combs
Is this a job for FFT and some blue tack? :)
PostPosted: Thu Oct 12, 2023 6:57 pm
First name: Victor
Last Name: Seal
City: Osseo
State: MI - Michigan
Zip/Postal Code: 49266
Man, you must have one heck of an ear. The only change in tone i ever hear is when i do my yearly string change.
These users thanked the author Victor Seal for the post: Hesh (Fri Oct 13, 2023 5:03 am)
PostPosted: Thu Oct 12, 2023 9:13 pm
The real test would be to remove the cap and see if the tone goes back like it was.
These users thanked the author Pat Foster for the post (total 4): BlindGuitar (Fri Oct 13, 2023 4:15 pm) • bcombs510 (Thu Oct 12, 2023 9:55 pm) • dofthesea (Thu Oct 12, 2023 9:26 pm) • Chris Pile (Thu Oct 12, 2023 9:15 pm)
PostPosted: Fri Oct 13, 2023 5:10 am
Where to start.
Never mind, I'll pass, enjoy.....
These users thanked the author Hesh for the post (total 3): Robbie_McD (Sat Oct 14, 2023 7:49 am) • bcombs510 (Fri Oct 13, 2023 7:02 am) • SteveSmith (Fri Oct 13, 2023 6:29 am)
PostPosted: Fri Oct 13, 2023 6:55 am
First name: Josh
Yeah you’re gonna wanna ditch that wood heelcap and get a brass heelcap if you’re really serious about tone
These users thanked the author joshnothing for the post (total 3): Kbore (Mon Oct 16, 2023 8:53 am) • Hesh (Fri Oct 13, 2023 12:37 pm) • bcombs510 (Fri Oct 13, 2023 7:03 am)
PostPosted: Fri Oct 13, 2023 8:04 am
First name: David
City: Napa
The only option is a tree that you fell yourself, stickered it and let it season for 45 + years.
These users thanked the author dofthesea for the post: Hesh (Fri Oct 13, 2023 11:12 pm)
PostPosted: Fri Oct 13, 2023 9:46 am
Last Name: Parker
City: Charleston
State: West Virginia
Zip/Postal Code: 25314
I think it is the glue holding on the heel cap that has the biggest impact on tone. beehive
These users thanked the author doncaparker for the post: Hesh (Fri Oct 13, 2023 11:12 pm)
PostPosted: Fri Oct 13, 2023 10:39 am
I don't doubt the OP heard a difference in tone because he has stated as such but the question is why? Because I can't for the life of me come up with a reason as to how a heel cap would affect tone. Perhaps OP should build a guitar with several snap in heel caps and run an experiment.
These users thanked the author jfmckenna for the post: Hesh (Fri Oct 13, 2023 11:13 pm)
PostPosted: Fri Oct 13, 2023 10:13 pm
First name: Josh
Audio memory is notoriously fallible and this has been shown time and time again in blind listening studies so, and I intend no offence whatsoever in saying this, I give no credence to claims of this type where there is a significant time gap (eg greater than 15 seconds) between the hearer listening to an instrument in each of two states.
I’m not saying there is no possibility that adding material to the heel would effect the tone. But in the case of this reported change, there’s no way to know if it was real, or imagined without a better test.
If we presume there was a change, how do we know the heelcap was responsible, rather than any one of a thousand variables, from subtle changes in RH and temp, strings seating differently at the bridge having been removed/replaced, a new instrument “opening up” (another reported phenomena that divides opinion) and so on. All of this would need to ge controlled for in a genuine test. If a change happened at it was due to the heelcap, was it because adding any heelcap changes tone? Would a maple heelcap change tone differently to rosewood? Would just sticking a lump of poster putty to the heel make a difference? Is more weight better? Should we be fitting lead heel caps? Carbon fibre?
To many known unknowns.
These users thanked the author joshnothing for the post (total 3): SteveSmith (Sat Oct 14, 2023 8:44 am) • jfmckenna (Sat Oct 14, 2023 8:20 am) • Hesh (Fri Oct 13, 2023 11:13 pm)
PostPosted: Sat Oct 14, 2023 6:54 am
First name: Ken
Last Name: Nagy
City: Goodrich
I don't doubt that somehow the tone got better. I have no idea why. Since it was just getting finished, it might have just found where it wants to be. Tensions set.
David, did you tune it up to pitch after putting the Rosewood heel cap on?
I am ALWAYS amazed when the G,B and high E strings get within a quarter tone of being in pitch, and they completely wake up. Just night and day.
Why be normal?
PostPosted: Sat Oct 14, 2023 11:14 am
First name: Eric
Last Name: Reid
City: Ben Lomond
Zip/Postal Code: 95005
What a lovely toast. I'll raise my glass and take it further: "To many unknowns!"
These users thanked the author Eric Reid for the post (total 4): Bryan Bear (Mon Oct 16, 2023 12:55 pm) • Kbore (Mon Oct 16, 2023 8:56 am) • Durero (Sat Oct 14, 2023 3:45 pm) • J De Rocher (Sat Oct 14, 2023 11:21 am)
PostPosted: Sun Oct 15, 2023 9:14 pm
First name: David
City: Napa
The heel cap would only make a difference if glued on with HHG.
PostPosted: Sun Oct 15, 2023 10:03 pm
Last Name: Parker
City: Charleston
Somebody needs to do some heel cap deflection testing. Or heel cap Chladni patterns. beehive beehive
PostPosted: Mon Oct 16, 2023 2:58 am
Last Name: Bradley
Country: United Kingdom
Is there a veneer between the cap and heel, or purfling? Surely that has to be taken into consideration!
