It is currently Thu May 01, 2025 1:14 pm
PostPosted: Wed Jun 07, 2006 3:14 am
Being new to woodworking I have a question about router bits.
For routing CF rod channels, Truss rodd channels, tenon channels, what is
the best type of bit?
Basically what are the differences and advantages/disadvantages of
1. Straight flutes
2. Downcut spiral
3. Upcut spiral.
My 1/4 inch is dull and needs replacing/sharpening and I am curious what
to replace it with. Currently I have a downcut spiral
PostPosted: Wed Jun 07, 2006 3:19 am
Im not hot on down cut or up cut router bits I like straight fluts. I do suggest 3 flut vs 2 flut. They run truer and cut cleaner
PostPosted: Wed Jun 07, 2006 3:23 am
Do any of you sharpen your bits???
Do you buy carbide vs HSS???
PostPosted: Wed Jun 07, 2006 3:31 am
I strop my bits on leather regularly but I dont sharpen because you can change the diameter pretty quickly. this means I buy a new bit when it is not cutting efficiently.
Carbide onlyMichaelP38875.5272685185
PostPosted: Wed Jun 07, 2006 3:33 am
Only carbide bits and I sharpen with a small credit card size, fine grit diamond plate. You only need touchup the flat of the cutter.
Kimlarkim38875.5243981481
PostPosted: Wed Jun 07, 2006 8:02 am
Andy, this single flute bit is ideal for the Allied truss rod slot. It cuts a slightly narrower groove than a double flute. Nice snug fit for Allied's rod.
The bit I like:
Ronold man38875.7126967593
PostPosted: Wed Jun 07, 2006 2:24 pm
Last Name: Beaver
City: Lake Forest
I like downcut, two flute end mills. Carbide steel is good. Never tried HSS. I don't use them enough to worry about sharpening. I just replace them when they start getting dull. For wider cuts in a router I use garden variety carbide tipped router bits.
Joe Beaver
Maker of Sawdust
