It is currently Thu May 01, 2025 9:39 am
PostPosted: Mon Jun 12, 2006 10:19 am
Yup. I hate it when that happens.
Live to Play, Play to Live
PostPosted: Mon Jun 12, 2006 10:46 am
And dude, it's like the archer scene in Braveheart...all those "arrows" coming at you all at once...
PostPosted: Mon Jun 12, 2006 3:01 pm
Gobar Dash Been there got the welts to prove it. when one goes they all go.
PostPosted: Mon Jun 12, 2006 7:48 pm
Mid the fray see dead and dying
Friend and foe together lying
All around the arrows flying
Scatter sudden death.
                       - Luthiers of Harlech Billy T38881.2017476852
PostPosted: Mon Jun 12, 2006 10:34 pm
There must be a way to build a go bar deck to prevent the go bars to leave the deck, maybe planks around the top or bottom...just thinking out loud here but i will be thinking further more...
PostPosted: Tue Jun 13, 2006 12:14 am
First name: Mark
Last Name: Tripp
City: Olympia
State: Washington
Zip/Postal Code: 98506
Yup. Still have a bit of a dent in the forehead. Fortunately my glasses for vision ARE safety glasses!
-Mark
Pullman, WA
trippguitars.com
OR
Find me on Facebook
PostPosted: Tue Jun 13, 2006 12:21 am
Thanks for the warning! I'd never heard of this happening.
Todd Rose
Ithaca, NY
PostPosted: Tue Jun 13, 2006 12:34 am
un-bound springs. I have read somewhere that you want 8lbs/sqin clamping force but I think that even may be exsesive. In my mind anything that overcomes the surface tention of the glue and holds the brace flush to the top or back would seem to get the job done. When I first started using a gobar deck I thought I needed aout 2" of bow in the bars. now I rig up so that I get about 1/2"-1" bow.
I have been popped in the mouth twice by bars letting loose so I guess a sports mouth piece may be a good piece of PPE (personal protective equipment) too MichaelP38881.4001851852
PostPosted: Tue Jun 13, 2006 12:46 am
Hmmm, I've been lucky so far and had not heard of this before either so thanks for the warning Jim and all!
PostPosted: Tue Jun 13, 2006 12:47 am
Hockey mask, or catcher's mask???!!!
PostPosted: Tue Jun 13, 2006 12:54 am
Good one Larry
PostPosted: Tue Jun 13, 2006 12:55 am
If you are really tall you might want to consider a...We wont go there MichaelP38881.4143981481
PostPosted: Tue Jun 13, 2006 1:11 am
MMMMHHHHH! And I ain't gonna drank outta one neither!
PostPosted: Tue Jun 13, 2006 1:13 am
In honor of this thread, I'm christening my Go-bar deck "The Red Ryder"...("you'll put your eye out"!!)....
PostPosted: Tue Jun 13, 2006 2:05 am
How steady is your go-bar deck? I originally just used all-thread as the "columns" in mine, pretty wobbly. I was also using 1/4" rods which I think are too stiff for go-bars, so it was pretty precarious. I cut some 2" PVC pipe on a miter saw to use for the columns, and just used the all-thread to tighten up the upper and lower deck to the PVC. I also switched to 3/16" rods. Huge, huge difference, way more stable. I'm still planning on doubling the thickness of the upper deck so I can use more go-bars at the same time.
Before:
After:
PostPosted: Tue Jun 13, 2006 2:19 am
[QUOTE=MichaelP] If you are really tall you might want to consider a...We wont go there [/QUOTE]
I'm with Michael here - I think it's time to wear a cricket box along with the "bo-boats" . . . and goggles . . . and respirator . . . and hard hat
PostPosted: Tue Jun 13, 2006 7:55 am
How about a bunch of bungy cords hooked onto the vertical rods, creating a mesh of sorts - the problem is you need to get in there and be able to manipulate the rods.
PostPosted: Tue Jun 13, 2006 8:27 am
Mine is three layers on the bottom, two on the top, with steel conduit covering the all-thread. Built like a tank.
The conduit is countersunk 3/4" into the top and bottom also.
PostPosted: Tue Jun 13, 2006 8:35 am
Jim,
Sure glad you're OK!
I did the same as Jon, and need to add thickness like Ron's.
Just got my new batch of 3/16" fg rods. The accumulated force from the 1/4" ones when gluing plates was just too scary.
PostPosted: Tue Jun 13, 2006 8:57 am
[quote]"The Red Ryder"...("you'll put your eye out kid"!!).... [/quote]
BB gun, with a compass in the stock and a thing that tells time! My favorite Christmas movie!
    I was thinking, go-bars could probably be restrained by some light cord attached to one end if it gets too hairy!
