It is currently Tue Aug 12, 2025 6:58 pm
Post new topic Reply to topic  [ 62 posts ]  Go to page Previous  1, 2, 3
PostPosted: Tue Jul 18, 2006 10:55 pm
Todd, would you mind copying me on those setup files?
PostPosted: Wed Jul 19, 2006 12:19 am
Todd, you are one special gentleman! Thank you! i saved up your post and will PM you my e-mail address, i will also follow your advice on the link belt and the book on maintenance!
Thanks again
PostPosted: Wed Jul 19, 2006 12:37 am
Another book I found to be very good Serge is "The Bandsaw Book" by Lonnie Bird.You can find it at Amazon.com if you are interested.Here it isDaveAndy38917.4059375
PostPosted: Wed Jul 19, 2006 3:14 am
Thanks Dave, i will check into that also!
PostPosted: Wed Jul 19, 2006 3:20 am
Todd, i found the book you mentionned at Lee Valley's!
http://www.leevalley.com/wood/page.aspx?c=1&p=46736&cat=1,46 096,46119&ap=1
PostPosted: Wed Jul 19, 2006 4:54 am
[QUOTE=RussellR] Hi Charlie
Nice to see you, I was wondering about you the other day as I hadn't seen you around.
Hows the building going ?[/QUOTE]
I a doing well, Russel, Serge, and everyone else who gives 2... :-)
I have had an extremely busy summer - with multiple inlaw visits, garden work, shop work, garden shed building, Im building a thickness sander, jigs and molds {still yes}
And for those of you who dont know - I have gotten interested in cactus growing since I was injured. It therefore makes this my busy time for my hobby as well.
It has been warm and beautiful here, and we really couldnt have asked for a beter summer so far - the kind of summer we just havent had in years around here.
So needless to say Im taking advantage of these sunny days, so I dont regret it come this Nov.
I have only had time to lurk here lately, but Im still around. Plus I sorta vowed that I would post regularily again until I had more to contribute, I feel that pretty soon I will.
Charlie
PS thanks for the info on the bandsaw guys!
PSS oh yeah I really tried to stay away from the swap meet - alas it was too strong a pull!
PostPosted: Wed Jul 19, 2006 10:34 am
Serge, another book to add to your shop collection is The New Best of Fine Woodworking - Workshop Machines. It is a compilation of numerous woodworkers, one of which is White. You can check it out at Amazon as well.Don A38917.8159259259
PostPosted: Wed Jul 19, 2006 12:14 pm
[QUOTE=ToddStock]
PS - Your saw can be set up to cut metal, as Phil is doing in the shot above (most excellent saw, Phil - is it a Gilliam (SP?) or scratch-designed?). Good capability to have for jigs, etc. Don't use a wood blade for this - buy a 14 tpi metal blade and make sure you really, really clean the saw out afterwards.
TMS[/QUOTE]
Todd -
I got the inspiration to build one from Fine Woodworker Magazine- July 1989. There were plans for a plywood frame saw by William Cornell. I ended up using about half of his details and designed the rest myself. In particular, I tried to design a very stiff frame. It's probably as stiff as most cast iron frames. Wood is a great engineering material if you pay close attention to the design.
The only tools I had (and used) to build it were a table saw and drill press ( and hacksaw). I did have to do a little welding, also.
As far as cutting metals - I've been using wood blades (6 tpi skip tooth) for aluminum at reduced speed ( about 1500 FPM) - they seem to work very well.
For steel (mostly 1/8 and 1/4 plate) I've also used blades meant for wood ( 14 tpi) but at a much slower blade speed- about 150 FPM, and they seem to work fine. If I were doing a lot of metal work, though, you're right - blades meant for metals would be better.
Serge -
I don't really have plans, but, if you want to build one, let me know and I'll start another thread with photos and details about what I did. Also, I plan to be at the OLF get-together in late July, so we could talk then. (You'll be there, right?)
Phil
PostPosted: Wed Jul 19, 2006 4:10 pm
Charlie, it's great to have news from you, please stay around, we'll benefit from some of your tips also bud!
Thanks Todd, i seriously will buy White's book for sure, it will be very useful with all the power tools i have around here and that i know next to nothing about their maintenance! The more info on those, the better!
Thanks Don, is this the book you are talking about?
http://www.leevalley.com/wood/page.aspx? c=1&p=52767&cat=1,46096,46119&ap=1
I sure will look into that also, Thanks Don!
Phil, yes, i will be there also! we can talk about it then since i already bought mine but please, do share what you know on this, if i decide i want a bigger bandsaw one day, i'll know what to do! And i'm sure there are other jigs makers here who would certainly benefit from it and appreciate it like i would! No pressure though! Thanks Phil
SergeSerge Poirier38918.0496527778
PostPosted: Thu Jul 20, 2006 4:46 am
[QUOTE=Serge Poirier]
Serge[/QUOTE]
Thats the one.
PostPosted: Thu Jul 20, 2006 5:44 am
Well, all I know is I had my old Rockwell all set up nice and tweaked, and no matter how hard I tried, I could never get cuts as good as a friends' MiniMax. Since getting the new Laguna set up, I've got consistant cuts that look like they've come off a planer...
Better saws are just better...
Food for thought.
PostPosted: Thu Jul 20, 2006 1:54 pm
Thanks again Don A!
Don W, i hear you well but the shop i work in isn't mine and i only have 110v in there, Laguna, seems to only have the 220v saws, even the LT 14 has that so i can't have it here and it's a real bummer because that's what i would have bought for sure. Oh well, i'm still an apprentice and for 2 guitars, i had 4 bandsaws come in this shop so i figure that the 5th one will be when i have a real shop of mine and makin' a living at it, i hope!
