It is currently Tue Aug 12, 2025 4:14 pm
Post new topic Reply to topic  [ 35 posts ]  Go to page Previous  1, 2
PostPosted: Mon Jul 24, 2006 1:28 am
First name: Mark
Last Name: Tripp
City: Olympia
State: Washington
Zip/Postal Code: 98506
Here's a hanger bolt:
-Mark
Pullman, WA
trippguitars.com
OR
Find me on Facebook
PostPosted: Mon Jul 24, 2006 2:03 am
Thanks Mark and Stephen, I realy did know that! Brain freeze on Monday morning. Thanks
DonovanD Stewart38922.4625115741
PostPosted: Mon Jul 24, 2006 5:41 am
The long dowel is for the threadfs to bite into something other than just end grain, and also strenthens the entire heel a lot.
For the record, I've been using modified hanger bolts for about a year now. Good enough for Collings, good 'nuff for me... No issues yet, and only needs a 3/16" holes, and in my case, leaves more dowel intact.
The simple butt joint has proven itself plenty sturdy in hundreds of thousands of Taylors, Bourgeois, H&D, and countless others. I've done around 100 of them, and see no reason for a tenon.... honest.
PostPosted: Mon Jul 24, 2006 5:55 am
First name: Mark
Last Name: Tripp
City: Olympia
State: Washington
Hey Mario,
In what way are the hanger bolts modified?
-Mark
Pullman, WA
trippguitars.com
OR
Find me on Facebook
PostPosted: Mon Jul 24, 2006 6:57 am
Shortened, then sharpened again...
PostPosted: Mon Jul 24, 2006 8:34 am
The issue is either too small of bore for the insert or the insert not tapping in square. Many bore a larger hole and glue in a hardwood dowel then bore the hardwood dowel slightly larger bore than the insert shank. This is a saftey factor if the dowel cracks it will not transfer to the neck. but I use The same thing as the LMI inserts and have hade no issues. I bore 1/64 the bore size andline with titebond before I screw it inMichaelP38923.4165509259
PostPosted: Tue Jul 25, 2006 12:52 am
First name: Mark
Last Name: Tripp
City: Olympia
State: Washington
Thanks Mario.
One more question if I may. Do you countersink the neck block where the nuts attatch to the hanger bolts? If so, do you cap the nuts, ala Collings?
-Mark
Pullman, WA
trippguitars.com
OR
Find me on Facebook
PostPosted: Tue Jul 25, 2006 4:31 am
Yeah, i countersink the bolt holes, using a 3/4" reverse spotfacer...
I place my interior label on the ehadblock, over the bolts.
PostPosted: Tue Jul 25, 2006 6:56 am
First name: Mark
Last Name: Tripp
City: Olympia
State: Washington
Thanks Mario!
-Mark
Pullman, WA
trippguitars.com
OR
Find me on Facebook
PostPosted: Wed Jul 26, 2006 3:42 am
First name: Tracy
Last Name: Leveque
State: CO
I used my first butt joint on my last, and I'll do it on all the rest of my builds. I also used a 5/16" dowel glued in first, then drilled my 1/4" bolt inserts. I got my hardware from Ace hardware. It is Stainless Steel hex threaded bolts, and steel inserts. Worked beautifully, and really cheap! Good luck!
